Should Any Manufacturers be
Heat Treating In-House? This debate has raged on
and off for a number of years-should
manufacturers heat treat in-house (captive heat
treating) or should the work be sent out to
commercial heat treaters? Recently it has moved
more to the fore front for many manufactures,
the reason being that when business conditions
become tougher, margins smaller everything is on
the table. Such is the case now. Recently we
have been averaging at least one phone call a
week from companies debating about sending their
work out or in some case bringing it in house.
We will give you three recent examples we have
come across; Case #1. A manufacturer of
reasonably heavy parts in the distant past heat
treated in house but for the past number of
years has been outsourcing to a local commercial
heat treater (roughly 60 miles away). Value of
the heat treating is approximately
$250,000/year. Margins for their product are
tighter, they have some extra space available
and the question came up “should we bring it in
house again as costs are going up because of
increased transportation costs”? This answer was
apparent after a 15 minute conversation. Because
of the weight and configuration of the parts
they had to be run in a cast link belt furnace.
The absolute minimum investment on their part
would have been $500,000 to install a furnace
line and the volume of work they have would have
kept the furnace running at most 1-2 days/week.
Not in a million years would this sort of
investment have made sense. Case #2. A captive
heat treater doing annealing that is seeing
volumes drop. What to do? Just a couple of years
ago this in house heat treating department was
kept full, but volumes have declined to the
point that their HT department can fulfill their
productions requirements in just 2 days a week.
Look for outside work to fill the furnace or
outsource? With the slim margins that
commercials work on it makes no sense to look
for outside work, especially since this is a
union shop. The only scenario that makes any
sense is outsourcing the heat treating
requirements, at the end of the day a fairly
straight forward decision. Case #3. This is a
rather unusual situation. In this case the
manufacturer has been outsourcing the heat
treating for quite some time, however the
nearest commercial heat treater is 400 miles
away. At first glance it does not make sense to
bring the work inside as it amounts to only at
most $100,000/year, however based upon the fact
that transportation costs are growing, turn
around times are horrendous and the fact that
the equipment they would need can be purchased
and installed for less than $100,000 bringing
the heat treating in house makes a great deal of
sense. In these three examples we see one
company that should continue outsourcing,
another that should and a third who should be
bringing their requirements in house. While
every situation is unique our feelings over the
years have become more solidified and that is
that virtually all companies should at least
take a good hard look at what their heat
treating is costing them vs.; what a commercial
heat treater would charge them to do the work.
Some situations demand in house heat treating, a
couple of examples would include large aerospace
companies with specialized, high end heat
treating where the volumes justify heat treating
in house and companies doing Induction work (an
easily repeatable process which can be turned on
and off at will). Incidentally the number one
reason why companies want their heat treating in
house? Surprisingly enough turnaround time as
opposed to cost savings. Most manufacturers
recognize that they are not going to save a
great deal (or anything) by doing the work
themselves but with just in time manufacturing
quick turnarounds are crucial. In fairness to
commercial operations who are constantly told
their deliveries are too long we will make the
point that as a manufacturer sending out $50,000
worth of heat treating/year in less than full
furnace loads you cannot expect a commercial to
hold a furnace available full time unless you
are prepared to pay through the nose for this
service. If you’re a captive heat treater and
would like to see if it makes sense to continue
down the road please let us know and we will be
more than happy to lend you our assistance.
