Nadcap & CQI-9 Compliance Made Easy
Draw/Temper for Sale
See something you need, click on the link or scroll through all the items for sale. Searching for something we don’t have listed, let us know.
Item # T352
Wisconsin Oven
Wisconsin Oven. Wisconsin Model SDB-8814-12E, maximum temperature – 1250F, inside working dimensions 4’W x 7’D x 4’H, 304 SS interior and ductwork, air operated vertical lift door with sefety latch to secure door in the open position, 7000CFM/10HP recirculating fan, 120KW on 480/3, 175 full load amps, digital controller, hi limit, chart recorder, process timer, roller hearth, load table with rollers.
Asking Price: $29,950.00 USD
Item # T340
Safed/Borel Annealing Furnace
Safed/Borel Annealing Furnace built in 1991. The working dimensions consist of: Diameter 400 mm, Height 500 mm. External Dimensions: 1800 mm x 1767 mm x 2412 mm. Maximum Temperature: 650 C with a maximum load capacity of 100 kg (not including baskets). Main voltage is 3 x 400V / 50 Hz, Control voltage is 230V / 24V. This setup includes a Eurotherm programmer, threshold controller, recorder, programmable clock, timing relay, control for water flow, vacuum pump, pressure reducer, and fire engine. Located in France.
Price on request.
Item # T339
Box Tempering Oven (4 Available)
Box Tempering Oven (4 Available). Manufactured by Eisenmann in 2002. Model HN-FNC-006. Working dimensions of 108” Wide x 96” Deep x 64” High. Natural Gas (3,200,000 BTU/HR). Operating temperature of 1200F. Stainless Steel Lined Recirculating Box Tempering Oven complete with Top-Mounted Alloy Recirculating Fan (20 HP – 13,000 CFM), Rear-Mounted Heater Box with Eclipse Burner System, Alloy Skid Hearth, Forced Cool Down Fan System (7,333 CFM), Vertical Rising Motor Driven Front Door, and Stationary Loading Table. Free Standing Control Panel with Eurotherm Digital Set Point Programmable Temperature Controller, High Limit, Chessel Strip Chart Recorder, and Honeywell Flame Safety System. Overall dimensions of 13’2″ Wide x 23’ Long x 17’8” High (includes Door Structure). Approximate weight of 32,000 pounds. Excellent condition.
Asking price is $72,500 USD.
Item # T336
Mesh Belt Temper Furnace 48" Wide
Mesh Belt Temper Furnace 48″ Wide. Continous belt temper furnace manufactured by Industrial Heating Equipment, Model # TF-5. Inside dimensions 10″ over belt, 48″ wide X 12′ heating. Gas fired, Eclipse package burner. Maximum operating temperature 1000 F. Temperature Controls: Free standing enclosed panel. Solid state digital readout indicating controller & overtemp. Top mounted brick lined combustion chamber houses high velocity stainless steel circulating fan. Steel lined work chamber has 8-1/2″ insulation. Stainless steel mesh belt on top of edge wire belt. Very good condition.
Asking $29,500 USD.
Item # T335
Batch Oven 37"H X 37"W X 25"D
Batch Oven 37″H X 37″W X 25″D. Batch type recirculating oven manufactured by Despatch, Model V-29-STD. Inside dimensions of 37″ high X 37″ wide X 25″ deep. Electrically heated 480/3/60, 12 KW. Operating temperature of 500F. Serial number 126552. Temperature Controls: Partlow indicating controller and Honeywell overtemp, timer. Double swing open doors. Side mounted recirculating fan. Adjustable horizontal air flow. Provisions for 12 shelves, 4 shelves included. Powered exhaust blower. Oven has been checked out and test fired and is ready for immediate shipment. Excellent condition.
Asking $6,500.00 USD.
Item # T325
Station Despatch Temper Furnace
3-Station Despatch Temper Furnace. Manufactured in 1980 by Despatch Industries, Inc. 3 Independently loaded and operated furnace stations with shared panel. Tops elevate off bases for loading and unloading. Work Zone: 22”W x 40”L x 25”H Each. Hearth Height: Estimated at 36-40” (Can measure for you). Max. Temperature: 850ºF with a Uniformity of +/- 25ºF (Center area of 12”W x 20”L x 10”H meets +/-10ºF). Electrically heated with a power of 490V/3Ph/60Hz. 3 West 4400 Temperature Contrl. & West 6700 Hi-Limit. (We can quote upgrade to new Super Systems, Inc. controls, if desired.). Just rebuilt. New heating elements, new hearth ceramics, New stainless steel side panels, new paint.
Asking Price: $39,500 USD, Offers considered.
Item # T321
Grieve Conveyor Oven
Grieve Conveyor Oven. Electrically heated 460/3/60/160kW/235 Amps. Maximum operating temperature of 650F. Working dimensions of 24” wide X 14” high X 42’ long. Controls; A Barber Colman 560 digital programmable temperature controller and a Barber Colman high limit safety. All control switches with indicating lights are flush mounted in the enclosure. SCR power controllers, high limit contactors, motor starters, fuses, relays etc. are mounted and wired inside the enclosure. Main power disconnect circuit breaker with panel mounted operator handle. Standard conveyor oven design with a flat wire conveyor belt. Three foot long charge table followed by a 42 foot long heating section divided into 2 zones of control. Each zone has separate heating elements and circulating fan located above the work chamber. Heated air is circulated down over the top of the belt for good uniform heating. Exhaust vents located on the top of each chamber. Access doors on the side for entrance into each zone. 4’ long discharge table is included with this oven. Very good condition.
Asking Price: $42, 000 USD.
Item # T320
Pifco Conveyor Oven
Pifco Conveyor Oven. Electrically heated 2 zone conveyor oven 480/3/60/144 kW. Maximum operating temperature of 600F. Work area; 72”W x 12”H x 25’L heated length. External dimensions 9’W x 10’H x 40’L – approx.. Controls; Mounted and wired in a free standing panel includes an Allen Bradley PLC with PanelView Plus 1000 touchscreen interface. Power to the heating elements are controlled through two (2) Allen Bradley “SCR” power controllers, one (1) for each zone. An Allen Bradley PowerFlex “VFD” controls oven conveyor belt speed. Standard two (2) zone electrically heated conveyor oven with a wire on edge belt. This oven has a 10’L load end and 8’L unload end with cooling. Access doors with “Brixon” door latches on both sides of oven and one in each heating chamber. Very good condition.
Asking Price: $59,000 USD.
Item # T318
Large Box Tempering Ovens (4 available)
Large Box Tempering Ovens (4 available). Built by Eisenmann in 2002, Model # HN-FNC-002. Working dimensions of 108” Wide x 96” Deep x 64” High. Natural gas fired, 3.2 million BTU’s per hour. Operating temperature of 1200F.
Description; Stainless Steel Lined Recirculating Box Tempering Oven complete with Top-Mounted Alloy Recirculating Fan (20 HP – 13,000 CFM), Rear-Mounted Heater Box with Eclipse Burner System, Alloy Skid Hearth, Forced Cool Down Fan System (7,333 CFM), Vertical Rising Motor Driven Front Door, and Stationary Loading Table.
Instrumentation; Free Standing Control Panel with Eurotherm Digital Set Point Programmable Temperature Controller, High Limit, Chessel Strip Chart Recorder, and Honeywell Flame Safety System.
OVERALL DIMENSIONS: Oven: 13’ Wide x 20’ Long x 17’8” High (includes Door Structure. (Shipping Dimensions: 12’6” Wide x 20’ Long x 10’8” High). Loader: 9’6” Wide x 12” Long x 4’ High. Approximate weight 20,000 pounds. Excellent condition, operational.
Asking Price: $72,500 USD each.
Item # T303
Pifco Temper Furnace
Pifco Temper Furnace. S/N 8177 built in 1988. Working dimensions of 126” long x 60” wide x 40” high. Overall dimensions of 13’ x 11’ x 11’ high. Comes with load and unload discharge tables and combustion fan. Maximum operating temperature 950 deg. F. Rated for 250 pound net weight x 37.4in long tray loaded every 15 minutes. Furnace holds three (3) trays. Approximate nineteen (19) minutes to operating temperature. Forty-five minutes in furnace @ 15 minute load cycle. Heated by one gas burner approximate rating 600,000 BTU/hour. Utilities required: 1000 BTU natural gas @ 5PSI, 480v 3Ph 60Hxz. Water 80 deg. F maximum @ 20PSI. Compressed air 60PSIG minimum. Adequate drain for water. Good condition.
Asking Price: $38,000 USD.
Item # T290
Tempering Ovens 36” X 48” X 36” (2 available)
Tempering Ovens 36” X 48” X 36” (2 available). Working dimensions of 36”W x 48”D x 36”H. Shells have just been completed and buyer has the option of Gas-Fired or Electric, Hearth Height, Burner Locations (Left or Right) and Panel Location. These can be completed, fully tested and ready to ship to your facility in 8-9 weeks at a very attractive price.
Please call for pricing.
Item # T286
Lindberg Box Temper
Lindberg Box Temper. Model 11-7212048-G14, S/N 24947. Working dimensions of 72” wide X 120” long X 48” high. Gas fired with a maximum operating temperature of 1200F. Vertical lift-air operated door, brick lined, 5 course refractory hearth, alloy roof baffles, alloy side wall ducts, dual zone burners-roof mounted combustion chambers with dual belt driven fans. Free standing prewired control panel. Good condition.
Asking Price: $65,000 USD
